7 posters
The Dragonfish revisited.
- Post n°31
Re: The Dragonfish revisited.
I reckon that'll do...fifteen minutes at half immersed, then fifteen minutes totally immersed. Not a drop of water inside, dry as a gorilla's armpit. I'm well pleased with that...onwards and upwards now.
- Post n°32
Cut the slot in the radio tray to take the motor, a Como 385...very low drain and very high torque, should be ok with that big prop on.
Just got to work out how to secure the motor to the tray, and that's another job done.
acrowot (Geof)- Guest
- Post n°33
i had better get my skates and stop messing around on my motorcycle the speed your going mines going slow in comparison
when you checked for leaks did you take the push rods out?
one other question is are you going to hold the end caps on with anything or just relying on the friction of the oring to stop the end caps coming of.
geof
geof
- Post n°34
Yea, c'mon mate..get stuck into it! We want to see it on the water!
My watertight tests were done minus the push rods, I just stuck a length of plastic insulating tape over the holes, I wanted to start from the bottom up, so to speak, and make sure that the wtc is watertight before I start to add anything, that way I have dry base to start from and it should be easier to identify any leaks in the future.
My end caps will just be secured by a good fit and a layer of vaseline, there's no pressure changes in the tube, so the old 'threaded rod and lock nuts' approach shouldn't be needed. I hope...
- Post n°35
Nothing on the tv, so that equates to me to building time..just drilled out the end cap and fitted the prop shaft tube. It needs to positioned properly, but I need the propshaft for that, and that's in the post. Still, it's one more little job done.
- Post n°36
The motor mount problem is solved...took me all of ten minutes.
Take an old toy boat motor mount, couple of minutes with a razor saw, and cut away most of it...drill two holes, and reinforce the underside of the tray with two styrene strips. Just needs a run over with the wet n' dry now.
Job's a good'un...or it would be if I could find the two screws that I took out of the mount prior to cutting it up!
- Post n°37
Job done..I never did find the two screws I took out of the mount though.
tattooed- AMS member
- Post n°38
looking good mate think i'll have to raid the stores at work to get you some supplies
- Post n°39
I'm ok at the moment mate, but I do need some alloy tube...it needs to fit over a 2.3mm shaft, to make up the coupling.
- Post n°40
how long does it need to be mate
- Post n°41
Oh blimey mate, I only need a couple of inches, just to increase the shaft diameter so it fits inside the coupling.
- Post n°42
My problem is that the motor shaft only clears the tray by 1mm, so as I see it there's two options:
1: Cut a slot in the the tray from the end cap up to the motor, reinforce it from underneath, and use a conventional coupling.
2: Make up a rigid coupling from alloy tube.
Having sat and worked it out on paper, I've decided that it's going to be the slot in the tray method. That will allow me to use a conventional coupling maybe those small Graupner ones. All in all, I think this will be the better way, albeit a bit fiddly to start with to cut the slot out accurately, but with concentration and my painkillers working, I think it can be done.
- Post n°43
I cut the slot in the tray this morning, and then discovered I'd made a major cock up..
I'd cut the slot too long, right up to the motor, so when I put the motor back in the tray to try it, it fell right through...gosh and bother it, I said. (or words to that effect..)
I've had to cut a tiny piece of styrene out and weld it back in the slot using plastic weld, so the front of the motor is supported again. Now it looks a right mess, so I've got some tidying and sanding to do...
- Post n°44
richard it will look fine when you put all the stuff back in any way cant see it under water ha ha
- Post n°45
I'm glad you said that, Geoff...saved me a lot of work sanding!
Here's the first attempt at repairing my cock up, with most of the equipment reinstalled...it's only now that I notice that the coupling between the motor and the stub shaft is misaligned, the hole has been drilled off centre, which has thrown everything out of line, it looks like a donkey's hind leg...dammed annoying. I've never really liked these type of couplings anyway, so it's going in the bin, and due to be replaced by a proper Huco or a Graupner jointed coupling when pension day arrives. Mind you, it would help if I'd have put the motor in straight, that makes it look even worse...think I'll go back to bed and start today again!
Then a kind soul on Facebook came up with this idea as part of a new tray, he's concerned that the repair might not be strong enough. This is a quick mock up using odds of carboard, but it gives you an idea of the design. It's very interesting, I'll have a go at making one up later, then I'll have one ready to go if my repair fails.
profesorul- Guest
- Post n°46
HI RICHRD,
Don't wait until is going to break!.If you can,do it know those Motor Support.
That small joint on thickness of the material is TOO week if You ask me.Look great already!.
For me the most important part is HOW YOU DO the Rudder/Dive planes conection.
I have serious problem with my Seawolf regarding these.
- Post n°47
richard would a solid coupling help with lining up the motor and stub shaft then the coupling on the outside this is what i am doing to my uboat or am i barking up the wrong tree
geof
geof
- Post n°48
I've already started on a whole tray, Marius...it will incorporate the new idea.
here's how I did my linkages...hope this helps?
- Post n°49
I've tried a solid coupling Geoff, and for some reason it vibrated something terrible, whether I hadn't lined things up properly I don't know, but it was awful. I'll need a jointed coupling at the stern end anyway, so I may as well put them at both ends, that way I'll be sure that things are smooth running as possible.
profesorul- Guest
- Post n°50
CRAYNG loud!...
I was badly inspired to stick the two halves of the aft cone!.
How should I do if I have these(from the second picture).
- Post n°51
My rear cone is glued down, Marius...
I'd do your rear planes exactly the same as mine are. Maybe you could make the rear cone removable, a couple of small self tapping screws would secure it nicely, and wouldn't show if you paint them black.
profesorul- Guest
- Post n°52
OK,I got the ideea.
- Post n°53
My hands and fingers are telling me that today is a 'day off' day, so it's no modelling for me today.
Here's the wtc so far...just need to install the linkages later. I'm going to try the repaired and strengthened tray, just to see if it will last, and for how long...in the meantime I can build the new designed one ready to install as and when and if it's needed. New couplings and stub shaft are on order.
- Post n°54
rich why dont you glue some half round waste pipe under the motor to support it mate job done and no worries
- Post n°55
Not enough room underneath mate, battery packs fit under the tray.
Not a problem now though, I've had the new version of the tray explained to me by the designer, and I've just started drawing it up on cardboard. Once it's built properly it will solve everything in one go.
Today at 1:58 pm by david f
