In total there are 10 users online :: 0 Registered, 0 Hidden and 10 Guests :: 1 Bot
» Newbie needs advice!
Modulated electric fields for submarine communication  in a "heads up" from Harry! EmptyFri Apr 26, 2024 1:58 pm by david f
Modulated electric fields for submarine communication  in a "heads up" from Harry! EmptySun Apr 21, 2024 6:09 am by geofrancis
Modulated electric fields for submarine communication  in a "heads up" from Harry! EmptyWed Apr 10, 2024 5:48 am by tsenecal
Modulated electric fields for submarine communication  in a "heads up" from Harry! EmptyTue Apr 09, 2024 3:40 pm by david f
Modulated electric fields for submarine communication  in a "heads up" from Harry! EmptyTue Apr 02, 2024 3:27 pm by tsenecal
Modulated electric fields for submarine communication  in a "heads up" from Harry! EmptyFri Mar 15, 2024 4:36 pm by david f
Modulated electric fields for submarine communication  in a "heads up" from Harry! EmptyTue Mar 12, 2024 1:56 pm by geofrancis
Modulated electric fields for submarine communication  in a "heads up" from Harry! EmptySun Mar 10, 2024 6:30 pm by cat
Modulated electric fields for submarine communication  in a "heads up" from Harry! EmptyMon Feb 19, 2024 9:24 pm by Michaelc
    Modulated electric fields for submarine communication  in a "heads up" from Harry! Empty Modulated electric fields for submarine communication in a "heads up" from Harry!
    Post  david f Fri Mar 11, 2022 2:48 pm
    I attach a recent email from Harry Brash in which he discussed some significant research which could be used for model sub control.
    Hi David
    I'm hoping that you are well and still using this email address.
    It's a while since I looked at model submarines but my friend Robin and I have decided to resurrect our GATO RC conversion. We once showed it at your Edinburgh model show in Inverleith park.
    We didn't give up on it but rather got diverted to another quite different project - an old car.
    I've just been scanning through the AMS forums which are always very interesting.
    I noticed some discussion about alternatives to radio as the remote control link. This seems to be because RC has moved to UHF plus which doesn't like going through water.
    In the 70's I was involved in ECG telemetry from divers. We tried several systems other than radio. We could get heartrate using an ultrasound (40kHz) pulse on the "R-wave" but the reflections prevented us sending the ecg waveform. We tried a magnetic link (coil to coil - transformer) but that falls off with the cube of the distance although it can work OK within a limited range. Our most successful system used a varying "static" electric field which was created by electrodes on the swimmer who also had the usual ECG electrodes on his chest. I think we used about a 50kHz carrier FM modulated and there were some issues keeping the transmitter signal (several volts at 50kHz) out of the ECG signal (about 1mV). The receiver was a couple of electrodes at the pool side about a metre apart feeding an amplifier around 50kHz then an FM demodulator. That sort of link could be used for controlling a model sub. It could probably work in seawater.
    However, my main reason for this email is to see how you are doing.
    Best wishes
    Harry
    Hi David
    Great to hear from you.
    I'd be very happy for you to quote me on the AMS forum as you suggest.
    I think that there was an underwater electric field broadcasting system in the San Francisco bay area, probably in the late 60's, which simply pumped audio via beach electrodes into the sea and divers could receive it via earpieces.
    Harry
    Modulated electric fields for submarine communication  in a "heads up" from Harry! Empty Re: Modulated electric fields for submarine communication in a "heads up" from Harry!
    Post  geofrancis Wed Jan 10, 2024 2:56 am
    I think this is what your friend was talking about, very interesting..to many Greek letters to wrap my head around.
    https://www.nature.com/articles/s41467-022-31042-8Modulated electric fields for submarine communication  in a "heads up" from Harry! 41467_10
    Post  geofrancis Wed Jan 10, 2024 12:43 pm
    https://cradpdf.drdc-rddc.gc.ca/PDFS/unc194/p801955_A1b.pdf
    Post  geofrancis Tue Apr 09, 2024 7:33 pm
    this is interesting
    https://www.youtube.com/shorts/wOhvJDEesb8
    david f and Marylandradiosailor like this post
    Post  geofrancis Sun Apr 21, 2024 6:09 am
    https://www.youtube.com/shorts/_hdq2x7KCCo
    I think the electric motors in the sub might cause problems.
      Current date/time is Thu May 02, 2024 3:52 am
