Our users have posted a total of 11072 messages in 1815 subjects
We have 839 registered users
The newest registered user is WilsonM
    openLRS and 2.4 Ghz and Submarines
    openLRS and 2.4 Ghz and Submarines - Page 4 Empty Re: openLRS and 2.4 Ghz and Submarines
    Post  david f on Fri Jun 12, 2015 11:03 am
    I think that it is the main supply voltage. (The voltage trend for microprocessors seems to be downward to reduce heating, perhaps?)
    All this stuff seems to be based on WiFi and mobile phone technology. If you look on the boards you will see a little sub board which is the radio frequency side, I think. You may be able to get data on these sub-modules - I don't know I'm just a user!
    openLRS and 2.4 Ghz and Submarines - Page 4 Empty supply voltages.
    Post  John Wrennall on Fri Jun 12, 2015 6:11 pm
    Further research reveals some Technical info on the HobbyKing website and that the RX and both TX modules are fitted with voltage regulators (3v3 I assume)
    for operating conditions:-
    RX module requires 3v7 to 15v
    Futaba TX and JR TX modules require 6v8 to 12v
    So normal battery systems can be used for operation but NOT for setting up/programming where 3v3 MUST be used.
    My order for rx / tx modules and other bits went in today.....
    David - I think you did a double paste of your latest shopping list.
              ( or are you on commission for large orders? )
    Post  david f on Sat Jun 13, 2015 8:39 am
    I understand your question better now - so you CAN feed more than 3.3v to the board supply.
    And no I don't get commission or freebies.I have made quite a number of purchases 3 x RXs and 2 x TX modules to - date. Fortunately this Hobbyking Orange gear is low cost but seems reliable and well-made.
    I have re-equipped my whole fleet and I don't intend to go back to 40Mhz. Just avoiding the dreaded peg board is reason enough for me!
    Post  tsenecal on Sun Jun 14, 2015 5:01 am
    guys,
    the openlrs based rx and tx modules actually have multiple power rails. for the RX, that would be the traditional power feed via one of the servo pins. max voltage there is 6v, but there is also the bank of programming pins (DTR, tx, rx, vcc, gnd, etc) that is a direct VCC set of pins from the arduino. due to the fact that the RF module (on the RX and TX) is driven at 3.3v, VCC for the board has been set at 3.3v... any higher and you fry the RF module (hopeRF RFM22b or hopeRF RFM23BP).
    same goes for the TX module, it has a set of pins that line up with pins on the transmitter and pins that are for programming. transmitter side can be as high as 12v, but programmer must be 3.3v
    both set of programming pins (rx and tx) follow same pattern, the pattern used by a standard FTDI programmer. so, to program the rx and tx, it is easiest to use a 3.3v ftdi programmer to connect the devices to your pc.
    Post  tsenecal on Sun Jun 14, 2015 5:05 am
    David, join the club, i now have 9 receivers and 4 transmitter modules. i won't be going back to 75mhz unless absolutely mandatory.
    1 of the receivers and two of the transmitter modules are special testing devices, but the rest will be used in submarines.
    that does not include one transmitter module i accidentally destroyed. (blew out the RF module by turning it on without an antenna attached)
    Post  tsenecal on Sun Jun 14, 2015 5:11 am
    my final post for the moment... i don't know if i have noted it on my subpirates thread, but there is a "missing" pin on the OrangeRX receiver that needs to have a connector soldered to it to get the main motor battery voltage fed back thru the telemetry. I will need to take a look on my subpirates thread, and i will add it there if i need to.
    for the electronically enlightened, it is port 10 or 11 - either can be used, on the OrangeRX module noted on this page of the OpenLRSng web wiki:
    https://github.com/openLRSng/openLRSngWiki/wiki/Hardware-Guide
    that 4 pin connector no longer comes soldered onto the pcb from the factory, so to use it, one must solder a connector into place. (or a wire directly to the individual pin)
    Post  david f on Thu Jun 18, 2015 10:14 am
    Many thanks Tim for the info on voltages and a grim warning about not plugging an antenna in!
    Also thank you for the information about the missing pin connection. This is probably why I couldn't get the battery voltage input working. (I used one of the analogue (temperature) inputs instead through the FrSky voltage divider board but you then don't get the correct scale and units on the display.)
    The main problem I am having with telemetry is the pesky servo glitching! Whenever I switch in telemetry the servos start to buzz. Control of the sub is still OK but it is not good for servos or battery life.
    Is this a problem with 433Mhz? (Perhaps flyers don't have this problem - more chance of interference in a subs packed interior?)
    Post  tsenecal on Thu Jun 18, 2015 1:42 pm
    david, it is a problem associated with 433.... and telemetry... the problem is 3 things:
    1) when you turn on telemetry, the receiver is now transmitting 50% of the time, so it is now the largest rf emitter inside the submarine. forget about capacitors on a brushless motor, this makes that look like the radar outline of a duck vs a b52
    2) the "antenna" wire lengths needed to carry that signal out to the servos (as interference) is only 6".... about the same length as a servo wire.... in the 75mhz and 40mhz world, that length needs to be over a meter.
    3) the antennas that all the systems ship with are monopole. they aren't grounded in any way (dipole), so they are less efficient and generate more noise.
    it seems to vary from submarine to submarine. my skipjack and delta are completely un-affected, while my blueback suffers so badly that the servos actually twitch about an 1/8th of an inch.
    in order to even make my blueback work, i had to wrap the servo wires around ferrite rings to kill the interference. something like this: http://www.ebay.com/itm/301198587261?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
    i put one of those on every servo wire (including esc)
    those are the exact ones i bought, and they dropped the interference to a point where the sub can now work. I assume that if you have room to install a proper dipole antenna, that would reduce the interference as well.
    Post  david f on Sat Jun 20, 2015 10:05 am
    Many thanks for the information. I find it amusing that I have just been cheerfully removing all those ferrite rings only to have to put them all back!
    (I used to use them a lot on 40Mhz gear in the "belief" that they cut down on servo glitches.)
    Certainly one of the very nice things about this openLRS UHF equipment is the smooth response without glitches. So it is a shame that the telemetry introduces interference.
    I wonder if a way out of this issue couldn't be done with a
    modification to the openLRS software itself?
    Would it be acceptable to have telemetry data less frequently? Perhaps only on demand?
    If so a signal from the transmitter could be used to turn telemetry on briefly.
    (There is already a similar feature in the lost model beacon part of the software. Pressing the walkie talkie transmit turns the beacon on. This works well.)
    Post  david f on Mon Jun 29, 2015 2:37 pm
    Some shots of  Dave J's excellent Type 9 operating on openLRS.
    http://www.theassociationofmodelsubmariners.com/t1555-furness-mbc-regatta-barrow-june-2015#9567
    Another pegboard heads for the skip! (Although my range problems with the Turkish Nordenfelt indicate that there are still some wrinkles which need to be ironed out.)
    Post  tsenecal on Wed Jul 01, 2015 7:32 pm
    John Wrennall wrote:Query?
    3v3 seems to be used a lot with these 433/458 modules. Is this just a programming "enable" voltage or the main supply voltage?
    Anyone got a link to the data sheets?
    It appears that today is not a day where my focus is at its best.... lets just say, i have answered the 3.3v question, as well as others.... but, for completeness, here are links to the data sheets.
    the systems use the HopeRF rfm22b rf module for the 100mw setup, and the rfm23bp for the 1 watt setup, here are hopeRF's spec sheets:
    http://www.hoperf.com/upload/rf/RFM22B.pdf
    http://www.hoperf.com/upload/rf/RFM23BP.pdf
    Post  tsenecal on Wed Jul 01, 2015 10:18 pm
    I just noticed that the OrangeRX 100mw futaba transmitter module on hobbyking.com is selling for $9.99
    Post  david f on Sat Jul 04, 2015 2:28 pm
    Good news about the reduced price for Orange modules.
    It is rather important to us that they carry on selling and making them. We wouldn't want the market to dry up for us as it has with lower frequencies.
    I have been doing some more antenna trials, mostly to solve the short range problem I've been having with just one model. (The Turkish Nordenfelt)
    I re-configured the telemetry option to help with this displaying on the LCD screen.(Tim's suggestion to include some ferrite rings does reduce the servo tremor.)
    I put in  a home made aerial (175mm) which was in water (insulated but sticking through a bulkhead into the free flooding area.
    It worked as well as the previous aerial inside the WTC - but still gave about half "normal" range!
    It is puzzling because I use the same WTC  with the Turkish Nordenfelt and get good range. The range seems to be specific to this one hull.
    At the same time, I re-commissioned my Holland 1 with open LRS. This has a great big aluminium sealing ring, great big aluminium piston tank  and a brushless motor. You would probably expect range problems with such  a packed small model  but it worked fine over 100's of feet - until you couldn't see it to control it!
    So all together rather puzzling but I will carry on the experiments with the Turkish Nordenfelt.
    Crossie
    Post  Crossie on Sat Jul 04, 2015 3:07 pm
    Hello David,
                       I have been following this thread with some interest because although I have several Futaba M6 Tx and Rx outfits on 27meg which should last my sub modelling time, progress is slow, I always feel it's a good idea to have a plan B handy, government being as it is. With regard to your problem with just one particular model led me to wonder have you used any carbon  fibre or aluminium filler powder in the construction which presumably is grp? Or even metalised finish or primer?
                   Trevor
    Post  salmon on Sat Jul 04, 2015 3:08 pm
    I have a friend who built a sub with carbon fiber, guess what does not go through it? Yes, radio signal.
    Post  david f on Sat Jul 04, 2015 3:44 pm
    Thanks all!
    No, the hull is fairly standard grp using polyester resin. Halfords plastic spray primer and satin black topcoat.
    My budget didn't stretch to carbon fibre, Tom! I don't think any of those paints contain metal and we did a range test in air which was fine (screening would have affected this, I think.) The problems seem to start when the model is in water.
    The model has long brass control rods and a brass prop shaft (all about 500mm long)
    I initially thought that the problem was the extensive metal superstructure but I have replaced it all with ABS (Plasticard)
    Next thing to try is swapping receivers (I'm told that Hobbyking stuff can have variable quality control.) or could it be some diffraction phenomenon (the shape of the water over the WTC??)
    Overall it doesn't mean a problem for openLRS, plenty of subs with no problems. It just makes its use more interesting!
    (This sub will be going to Norwich "as-is" in any case.)
    Post  salmon on Sun Jul 05, 2015 5:29 pm
    is there any chance the water is getting to the antenna wire core? If you swap thar RX to another boat that has the antenna in the wet does it work. I guess I am saying does it follow the antenna, RX, or boat.
    Post  david f on Mon Jul 06, 2015 9:04 am
    The antenna wire is inside a 4mm nylon tube which goes through a gland in the WTC bulkhead. The end of the nylon tube is sealed with a silicon rubber cap. No water coming in there.
    Yes, you're right it does now come down to the antenna, RX or boat. So the next step is to try swapping the RX with stock antenna which worked well in the Holland. If there is no range improvement, then put the same antenna and RX in the same WTC back in the Turkish Nordenfelt (which worked well at Bournville).
    If that continues to work well then it just has to be something about the Russian Nordenfelt hull as it sits in the water.
    Subs are always interesting!
    Post  david f on Sat Jul 11, 2015 11:05 am
    Well I have carried out a significant experiment this week out on the pond to investigate the low range with the Nordenfelt. (about half the "typical" range.)
    3 models all using openLRS (Holland, Turkish and Russian Nordenfelts.) Telemetry on and monitoring RSSI with the LCD. Stock antenna used throughout.
    The Nordenfelts share the same WTC.
    The first thing was to test if a sub-standard RX was the cause. So I swapped the RX's over between the Holland and the Nordenfelt WTC. Result - no change.  The Nordenfelt was still poor and the Holland was very good. So RXs are not the problem.
    I then swapped the WTC back to the Turkish Nordenfelt. A rather shock result - the range was also poor.
    This was a surprise because I have used this Turkish Nordenfelt several times in the past with good range  (not least at the Bournville event.)
    So the conclusion is that it is some detail about the configuration of the internals of the WTC. It is densely packed and had I changed this detail since Bournville?
    I tried moving the RX and antenna up to the top of the WTC (it had been at the bottom so deeper underwater?) No improvement in range.
    That is where things stand to date. I will take the Russian Nordenfelt to Norwich as it is.
    It hasn't turned me off openLRS. It has very significant benefits and I don't expect to be using 40Mhz again. (I have just ordered and received another 2 Hobbyking Orange openLRS receivers.) It does however still have some development aspects to sort out.
    Over to you out there to have a go and report back.
    Post  david f on Sat Jul 18, 2015 11:56 am
    A piece I wrote for the Barrow in Furness MBC magazine. It is a summary of where we are. (Included with permission.)
    GOING ORANGE - trials of open source Long Range System(openLRS) on 458Mhz.
    You may have recently noticed Dave Jacques and me at the pond with
    strange stubby aerials and small orange boxes plugged into our
    transmitters.
    Well we have been doing the first trials of this technology for
    model submarines in the UK.
    You may be aware that in recent years model submariners have been faced
    with a dilemma created by the widespread adoption of 2.4Ghz equipment.
    This technology is a significant advance with big benefits for the
    modeller - mainly  being able to drop the dreaded pegboard.(The radio
    "frequency hops.") The only problem for the sub modeller is that 2.4Ghz
    is hopeless since it penetrates less than an inch of water!
    So sub modellers have been faced with the slow death of their hobby by
    having to rely on a small and diminishing stock of second hand 40Mhz
    equipment.
    But then along came First Person View (FPV) flyers. They needed longer
    ranges than were possible with 2.4Ghz. Open source software (openLRS)
    was developed by their community. This incorporated a lot of technical
    advances, frequency hopping, use of data packets and error checking,
    telemetry and even a useful "lost model beacon" transmitted by the
    receiver. (Transmitters and receivers both transmit and receive.)
    A model submariner in the US (Tim Senecal) noted that this technology
    worked well for subs at 433Mhz.
    We saw that the 458/459 MHz band was available for air and surface
    modellers in the UK. The openLRS software could be set to this
    frequency. We checked with the BMFA that this was legal. OpenLRS
    equipment is easily and cheaply available from a number of suppliers
    (including Hobbyking)
    And so that is where we stand at the moment. The equipment seems to work
    reliably and well. So far we have only tested it with 2 people using it
    simultaneously. So maybe model subs have a future in the UK!
    bwi
    bwi
    Post  bwi on Wed Jul 29, 2015 12:07 pm
    Hermann wrote:Hi David,
    the 433MHz band is a band for so called ISM Equipment (Industrial, Scientific and Medical) and in this scope also radio control with so called low power devices with a maximum transmitting power of 10mW are still legal, so remote car key control may be used and other applications for closer distances. But in former days 500mW transmitting power was permitted for model Radio control and that was cancelled. I think 10mW would be too low in practice for submarine purpose.
    Maybe you will find a little more 40MHz equipment on the German ebay platform but I am not so sure.
    And as I know obviously most of the German model companies do not have 40MHz RC sets in their program any more.
    Even worse - the two biggest companies, Graupner and Robbe, had got severe financial difficulties. Graupner went bankrupt about one or two years ago and was bought eventually by that Korean Company SC that made the RC sets for Graupner. Today Graupner is not the same as it was as the equipment for model production had to be sold. And actually Robbe has also difficulties. Perhaps the withdrawal of the model submarine kits by Robbe was a first indicator for upcoming financial problems. We must see how the story will go on.
    The key problem in my opinion is the lack of young people following us "old men" in our Hobby - so one day   the market will become too small for several big model companies. In my youth that is more than 40 years ago modelling was of very great interest among my friends at School, our favorite literature in the breaks were the catalogues of Graupner, Robbe, Hegi, Engel, AeroNaut ..... And in every mid sized town you could find a model shop or at least a toy shop with a model department. And today?
    Klaus-Dieter
    During my first look around I thought it was also prohibited in Belgium....so chapter closed. But this 433MHz stuff kept running in the background of my CPU. So I have made some inquiries concerning the Belgian allowable broadcasting frequencies. It's allowed to broadcast in the 433 MHz but with a max power of 10mW. Same as in GER.
    So I asked Tim (tsenecal) if he was still running his 433MHz system with the power of the TX at 6mW output as in the beginning and if he had any problems with it.
    If so this could open some opportunities for me.
    He made some test and bought some equipment to give me a proper answer (And what an Answer I got).
    You can find it here:
    http://www.subpirates.com/showthread.php?5173-OpenLRS-433mhz-RX-and-TX-modules-what-it-is-where-to-get-it/page3
    From post 29 onwards
    So the system works properly below 10mW, so it can be used here too.
    Thanks again Tim.
    Grtz,
    Bart
    Post  david f on Sat Aug 01, 2015 10:36 am
    That's very good news!
    Let us know how you get on.
    bwi
    bwi
    Post  bwi on Sat Aug 01, 2015 6:35 pm
    david f wrote:That's very good news!
    I will do David.
    Grtz,
    Bart
    Post  tsenecal on Thu Aug 06, 2015 6:31 pm
    guys,
    i have posted a couple replies over on subpirates on some new 433mhz stuff i have been playing with. nothing earth-shattering, and when i finally get a chance to really play with them (local boat club is having its annual regatta in a week) i will post "reviews" of the new hardware here, subpirates, and subcommittee.
    starting with post #5 on this link:
    http://www.subpirates.com/showthread.php?5255-Yet-another-Transmitter...&p=53176#post53176
    and a new thread:
    http://www.subpirates.com/showthread.php?5256-Yet-another-another-Transmitter....
    bwi
    bwi
    Post  bwi on Thu Aug 06, 2015 6:42 pm
    I'm in the process of buying an secondhand Futaba T9CP TX with a 35Mhz and a 2.4Ghz module, nothing more, no RX.
    The guy wants 90 GBP (140 USD) for it. Is this fair and square?
    I have no idea I haven’t been into this for a very long time.
    Thks
    Grtz,
    Bart
      Current date/time is Sat Feb 29, 2020 12:03 am
