Need a Little advice.
I'm having fluttering on my rudders and dive planes when I activate the Engel 824EA using the Engel UNI
Prior to adding the UNI and Piston Tank all three servos and ESC worked perfectly Since this is my first R/C I was patting myself on my back, but alas too soon, I guess?
Here's what I'm using Rx Futaba R168DF (75mhz in US), Rokraft 120uP, Engal EA825-6 Channels. Rx Cannels 1+2 Rudder and Rear Dive Plane, Channel 3 ESC, Channel 4 Front Dive Plane, Channel 5 the Engal Piston Tank. I disconnected the center lead (White) from the RX to the ESC. During my testing I'm using a battery pack for Rx power but will be using a BEC.
Does anyone have an idea of what's causing the servos to flutter when the Piston Tank is activated? Per Engel the Motor has built in noise suppression. I have added noise suppression on the two motors
Thanks John
Thanks John
