gearbox dissembled,the front case is no longer needed (the one with the large steel bush).
In total there are 14 users online :: 0 Registered, 0 Hidden and 14 Guests
We have 1005 registered users
tieratus
treeboa
johnrobinson
ajg141
NicK
17 posters
Piston Ballast Systems
- Post n°61
Re: Piston Ballast Systems
- Post n°62
rear case with the ideller shaft and bronze bush,this will be used as a drilling template.
- Post n°63
returning back to the brass strip,at the intersection of the two line previously drawn centre pop and drill a 2.5mm hole.
- Post n°64
Place the idler shaft in the hole,place the gearbox rear plate on the shaft as shown,drill a second 2.5mm hole using the old gearbox plate as a template (drill through the hole previously marked with an arrow insuring that the hole is on the centre line, I centre pop through the hole just to help keep the drill on the centre line).
- Post n°65
another view
- Post n°66
the second hole drilled.
- Post n°67
now place the gears on the new gearbox plate and check that the mesh feels ok.
- Post n°68
for the third hole,motor drive messure with a pair of calippers between the ideler shaft hole and the large motor hole on the original gearbox,this needs to be as accurate as poss,but it is ultra crittical.
- Post n°69
now transfer the calipers to the brass gearbox plate mark centre pop and drill another 2.5mm as shown.
- Post n°70
now mark a line and cut of at around three inches,as shown.
- Post n°71
now cut another plate the same as the first.
- Post n°72
as with the first plate mark a hole 1inch from the end drill a 2.5mm hole,put the idler shaft in the hole lay the first plate on top of it clamp together and thansfer all the holes to the second plate.
- Post n°73
holes transfered to second plate.
- Post n°74
Nigel,
Thank you!
This is so exciting!
Thank you!
- Post n°75
now take a 4mm dia prop shaft (the dia of the inner shaft),the type with top hat bearing's,knock out the bearings and put the outer shaft aside to be used later,the inner shaft is not used.
drill out the first hole in the gearbox plates to match the bearing dia,in this case it was .250 inch.
- Post n°76
now open up the third hole in both plates to 10mm to take motor sholder.
- Post n°77
now tap the bearings into the first hole on both plates with the shoulders faceing inward(towards gears).
- Post n°78
next take the main gear and shaft,cut a piece off tube to fit over the shaft,about an inch longer than the shaft.
- Post n°79
next place the shaft and gear inside the tube,put in a vise and push the gear of the shaft as shown.
- Post n°80
shaft and gear seperated,shaft is not used.
- Post n°81
next find a 4mm brass nut and a small file.
- Post n°82
This is the tricky bit,taking your time and insuring that you keep the nut central carefully file the round hole in the gear to a hex that will allow the brass nut to fit tightly in it,its not as difficult as it sounds the trick is to take your time,if you over do it a bit yu can gentley tap the edges of the nut with a hammer to expand it then push the nut into the gear in the vice.
- Post n°83
now lossly asemble the gearbox as shown place the piston shaft through the gearbox and insure that the gear train runs freely.
- Post n°84
take the gearbox apart again and locate the motor plate(aly one)place over the motor hole put the drill shank into the motor plate and gearbox case locate motor screw holes (long slots)with a 2.5 mm drill transfer motor holes to the gearbox as shown,then transfer to the second gearbox plate.
- Post n°85
counter sink the motor screw holes on the inside faces.
