In total there are 4 users online :: 0 Registered, 0 Hidden and 4 Guests :: 1 Bot
» today's work
Piston Ballast Systems - Page 2 EmptyYesterday at 3:53 am by merriman
» The SubDriver becomes Modular
Piston Ballast Systems - Page 2 EmptyThu Jan 16, 2020 2:04 pm by merriman
» Model Boats magazine - January 2020 - Jam Jar Sub
Piston Ballast Systems - Page 2 EmptyThu Jan 09, 2020 9:17 am by david f
Piston Ballast Systems - Page 2 EmptyTue Jan 07, 2020 1:59 pm by david f
» E Class British - E11
Piston Ballast Systems - Page 2 EmptyTue Dec 31, 2019 3:40 pm by Deep Diver (Fred)
» U Class British - ORP Dzik ( built in Barrow)
Piston Ballast Systems - Page 2 EmptySun Dec 22, 2019 1:19 pm by david f
» Things a prospective submariner does not want to hear
Piston Ballast Systems - Page 2 EmptyThu Dec 19, 2019 3:45 pm by merriman
» Zero Bubble design NEW KIT
Piston Ballast Systems - Page 2 EmptyFri Dec 13, 2019 10:47 am by Davidh
» Pinger 2 - Ultrasonic
Piston Ballast Systems - Page 2 EmptyTue Dec 03, 2019 2:32 pm by david f
Our users have posted a total of 11046 messages in 1810 subjects
We have 833 registered users
The newest registered user is Nicolas47
    Piston Ballast Systems - Page 2 Empty PISTON TANK
    Post  nigele(ADMIN)2 on Sun Sep 11, 2011 9:02 pm
    Piston Ballast Systems - Page 2 100_1211
    4,now place the piston on a bench face up,if you look at it you will notice four triangular web',they meet in the centre of the piston crown,these web's need to be cut away to allow insertion of a 2mm nut in the centre of them,I use a modelling knife to do this,insure that the nut is a good fit an is on centre,
    SEE PHOTO.
    5,when you have done that find a drill that will fit nicely through the nut you have inserted in the piston crown and drill strait through the nut and the piston,this is best done on a drill stand,but with a bit of care can be done with a hand drill.
    6,now remove nut from the piston and open the hole in the piston up too 2mm,then install a new nut in the piston crown,brass or stainless is best.
    Post  nigele(ADMIN)2 on Sun Sep 11, 2011 9:29 pm
    Piston Ballast Systems - Page 2 100_1212
    7,you now need a length of 2mm brass threaded rod,6inches should be fine for most tanks,this can be made from stock brass rod or bought.
    8,screw a 2mm nut an inch down the brass rod followed by a 2mm washer then screw the rod through the piston until the rod end is flush with the top of the nut installed in the piston web earlier,put a small amount of blue loctite on the threaded rod at the bottom of the piston and bring the second nut with its washer up to it and just nip it up gentle,then leave it to set,
    8,re-install the seal pust the piston and rod back into the outer cylinder,and there you have it a cheapskate cylinder.
    I will sort out the gearbox details tomorow.
    YES I KNOW THE ROD I HAVE USED IS NOT THREADED,I COULD NOT FIND ANY SO THAT'S JUST AN OLD PROP SHAFT
    Piston Ballast Systems - Page 2 Empty Re: Piston Ballast Systems
    Post  salmon on Mon Sep 12, 2011 12:42 am
    Nigel, Thank you for the beginning instructions! You are a man of your word!
    This is excellent. I can't wait until part 2.
    Peace and Cheers,
    NicK
    Piston Ballast Systems - Page 2 Empty thanks
    Post  NicK on Mon Sep 12, 2011 10:28 am
    Thanks for all the information .. Time to hit the drawing board ....
    Do I unpack my Gato now ............. !!!! Or wait until I have some time to myself !!!!!
    Post  Tom(ADMIN) on Mon Sep 12, 2011 10:33 am
    Get it started...
    Post  Tom(ADMIN) on Mon Sep 12, 2011 8:01 pm
    Apologies from Nigel, he won't be able to complete this post tonight, his area has a massive power cut, so h'e unable to use his computers.
    Richard(ADMIN)
    NicK
    Post  NicK on Mon Sep 12, 2011 8:22 pm
    Hamster tired or the wheel broke?
    Post  salmon on Mon Sep 12, 2011 8:34 pm
    Wow, sorry to hear that he is without power! Certainly waiting for the rest of the instructions builds anticipation. I just pray all is well with Nigel during this time.
    Post  Tom(ADMIN) on Mon Sep 12, 2011 9:52 pm
    He's mighty pissed off, can't use the 'net, can't charge laptop or mobile phone, and reduced to sitting in his campervan with gas lighting and cooking.
    NOT a happy bunny!
    Post  salmon on Mon Sep 12, 2011 10:21 pm
    Can't blame him. I would probably be the same.
    Post  profesorul on Tue Sep 13, 2011 6:53 am
    I'm SORRY to hear that.I really hope he and his family are OK.I hope the problem wheel be solved most quickly as possible.
    All the best
    MARIUS.
    Post  david f on Tue Sep 13, 2011 9:26 am
    Well at least it needs a hurricane remnant to keep our Chairman quiet!
    Post  Tom(ADMIN) on Tue Sep 13, 2011 9:33 am
    He phoned me last night, muttering about an almost flat battery in his mobile phone and he couldn't charge it up, never had such a quick call from him!
    Post  david f on Thu Sep 15, 2011 9:17 am
    Nigel phoned me the other night to apologise about his lack of a reply - his power is still off!
    I always thought of Essex being an urban county but he is right out in the country. He has a generator and apparently the electricity company is dropping off fuel to him!
    He mentioned that Salmon is looking for a very small piston tank. By way of a fill in, have you seen the photo on page 49 of Norbert Bruggens book, Model Submarine Technology? (Worth getting if you haven't got it.)
    This shows a "20 ml tank for the Red October plastic model" It is directly driven from a powerful servo using a rack and pinion arrangement. Very small and simple and, of course, proportional.
    Post  salmon on Thu Sep 15, 2011 4:10 pm
    I just saw his book on ebay and amazon. Thank you for the tip! I will look it up. Please, let Nigele know there is no pressure and I do not want him to give it a thought at this moment. When he can, I am sure he will. I am sure he has more important things to worry about.
    Post  salmon on Sun Sep 18, 2011 8:40 am
    I ordered the book by Norbert Bruggen and hopefully in the next week I will get it. I went to the hardware store and picked up some threaded rod to build a piston with. The only type they had is zinc plated....will that work? Stainless steel or brass are probably better, but have not seen it yet.
    Post  david f on Mon Sep 19, 2011 8:32 am
    That shouldn't be a problem as long as it doesn't rust. I've used SS. The only other advice I've heard is to make the easily replaceable bit of softer material - brass, say, for the middle threaded section.
    BTW I have got my original single syringe setup now working as a double syringe setup with a capacity of about 70ml. I will put some photos up soon.
    Post  david f on Tue Sep 20, 2011 10:32 am
    http://puremtc.com/info_faq/ballast_system/index.htm
    This was an interesting link which I spotted on Model Boat Mayhem.
    An interesting way of doing things but I see that it is no longer commercially available.
    I wonder what the mysterious slime sealant was?
    Post  salmon on Sat Sep 24, 2011 1:05 am
    How is Nigel doing?
    treeboa
    treeboa
    Post  treeboa on Sat Sep 24, 2011 12:42 pm
    david f wrote:http://puremtc.com/info_faq/ballast_system/index.htm
    as you say an interesting system, especially if space is of a premium, to my mind if the ` sealant ` needs replacing it cant harden in any form, so it begs the question is it a silicone grease
    my worry would be if the piston ` cocked over` as the pull from both sides is offset, if it did/does then it will be adding a wear mark into the tube over time, this could allow water under pressure to enter the air side or lose compressed air into the free flood side which only has the depth pressure
    Post  salmon on Sat Sep 24, 2011 8:28 pm
    Good point Treeboa. I look at the string or pulley as a weak point, but since I have not seen one of these it is just conjecture on my part.
    Peace, Tom
    Post  Hermann on Sun Sep 25, 2011 8:45 pm
    Hello everyone,
    last week I had the opportunity to make some photographs of another selfmade piston ballast system. That modeller (his name is Wilhelm Bauer) has used some brass tubes and has installed three pistons in his model for trimming/ leveling. Maybe they look a little old fashioned but they work.
    Piston Ballast Systems - Page 2 Piston12
    Piston Ballast Systems - Page 2 Piston11 [url][/url]
    Post  Tom(ADMIN) on Sun Sep 25, 2011 8:56 pm
    Superb workmanship!
    Post  Hermann on Sun Sep 25, 2011 9:24 pm
    Hello Richard,
    Wilhelm (William) would have been very pleased by your comment - but sadly he died more than hundred years ago (in 1875). But that model submarine (his 3rd, built 1852) has been preserved in the technical museum at Munich (where I took these photographs). You can see that the piston ballast system is a really old method. As I can remember even David Bushnell had a piston a system installed in his "Turtle" much earlier (but that was a big one and not a model)...
    Best regards
    Piston Ballast Systems - Page 2 Bauer_10
    Piston Ballast Systems - Page 2 Origin10
    Piston Ballast Systems - Page 2 Descri10
    p.s.: I think Wilhelm would have been happy if he had got a radio control for his model in those times...
    Last edited by Hermann on Sun Sep 25, 2011 9:29 pm; edited 1 time in total (Reason for editing : adding p.s.)
    Post  salmon on Sun Sep 25, 2011 10:58 pm
    I pause in awe. That is really amazing and a testimony to the skills of the creator. Than you for sharing!
      Current date/time is Sat Jan 18, 2020 9:39 am
