In total there are 4 users online :: 0 Registered, 0 Hidden and 4 Guests :: 1 Bot
» today's work
CSS PIONEER - Page 5 EmptyToday at 9:23 pm by merriman
» 3D printed sub kits
CSS PIONEER - Page 5 EmptyYesterday at 8:34 am by Deep Diver (Fred)
» RC for Submarines
CSS PIONEER - Page 5 EmptyYesterday at 5:54 am by tsenecal
CSS PIONEER - Page 5 EmptyTue Mar 24, 2020 11:27 am by david f
» Telemetry on openLRS
CSS PIONEER - Page 5 EmptyMon Mar 23, 2020 1:21 pm by david f
» stretching sprue
CSS PIONEER - Page 5 EmptyThu Mar 12, 2020 1:13 pm by merriman
CSS PIONEER - Page 5 EmptyThu Mar 05, 2020 2:30 pm by david f
CSS PIONEER - Page 5 EmptyWed Feb 26, 2020 10:30 am by david f
CSS PIONEER - Page 5 EmptyMon Feb 17, 2020 11:10 pm by C-3PO
Our users have posted a total of 11099 messages in 1818 subjects
We have 845 registered users
    CSS PIONEER
    CSS PIONEER - Page 5 Empty Re: CSS PIONEER
    Post  nigele(ADMIN)2 on Sat Feb 18, 2012 5:08 pm
    CSS PIONEER - Page 5 100_1432
    Post  nigele(ADMIN)2 on Sat Feb 18, 2012 5:15 pm
    CSS PIONEER - Page 5 100_1433
    When gel coat has fully cured cut a piece of tissue using the same patten used to make the mould and lay in the mould,stipple resin on top of it making sure that the edges along the taped face stand up in the air,allow the tissue to fully dry before going any further,repeat this on the second half hull.
    Post  nigele(ADMIN)2 on Sat Feb 18, 2012 5:23 pm
    CSS PIONEER - Page 5 100_1434
    This is how it should look with the tissue applied,the small centre mould is a rubbing strip for the boat just in case research shows that the original boat was fitted with them.
    Post  nigele(ADMIN)2 on Sat Feb 18, 2012 5:30 pm
    CSS PIONEER - Page 5 100_1435
    When the tissue is fully dry add two layers of 300gsm matt cut from the patten,these are added wet on wet,this means that the matt is resin coated before being applied to the mould,again insure that the matt stand up at the edges as shown.
    Post  nigele(ADMIN)2 on Sat Feb 18, 2012 5:34 pm
    CSS PIONEER - Page 5 100_1436
    Another view of both half hulls in the mould.
    Post  nigele(ADMIN)2 on Sat Feb 18, 2012 5:42 pm
    CSS PIONEER - Page 5 100_1437
    When the matt has fully cured, take a sharp stanley knife and run it down the mould face along the joint edges, don't try to cut it in one go, keep running the knife down the edge gently until the excess is removed. Ensure that the knife runs along the tape so as not to damage mould face.
    Post  nigele(ADMIN)2 on Sat Feb 18, 2012 5:45 pm
    CSS PIONEER - Page 5 100_1438
    Another view with excess removed.
    Post  nigele(ADMIN)2 on Sat Feb 18, 2012 5:50 pm
    CSS PIONEER - Page 5 100_1439
    Now remove both half hulls from the moulds.
    Post  nigele(ADMIN)2 on Sat Feb 18, 2012 5:56 pm
    CSS PIONEER - Page 5 100_1440
    Clean up hull edges with a rough file,insure that the long edges that join together have the burr removed but no more,when this is done wash the moulds and the half hulls and fully dry.
    Post  nigele(ADMIN)2 on Sat Feb 18, 2012 6:07 pm
    CSS PIONEER - Page 5 100_1441
    Tape round the front and rear edges of the mould with masking tape as shown,cut two lengths of 1 inch alloy foil tape the full length of the hull plus an inch.
    Post  nigele(ADMIN)2 on Sat Feb 18, 2012 6:12 pm
    CSS PIONEER - Page 5 100_1442
    Tape the two half hulls together at the front and rear insuring they line up correctly,as shown.
    Post  nigele(ADMIN)2 on Sat Feb 18, 2012 6:19 pm
    CSS PIONEER - Page 5 100_1444
    Now join along the whole length of the hull using the alloy tape,removing the masking tape at the front and rear of the hull as you go,ensure that the alloy tape is pushed down on to the hull firmly and flat.
    Post  nigele(ADMIN)2 on Sat Feb 18, 2012 6:22 pm
    CSS PIONEER - Page 5 100_1445
    Place hull back in the mould insuring that it is the correct way up.
    Post  nigele(ADMIN)2 on Sat Feb 18, 2012 6:27 pm
    CSS PIONEER - Page 5 100_1446
    Place the other half of the mould in place and bolt them together.
    Post  nigele(ADMIN)2 on Sat Feb 18, 2012 6:31 pm
    CSS PIONEER - Page 5 100_1447
    Looking down the inside of the hull showing the lines to be joined.
    Post  nigele(ADMIN)2 on Sat Feb 18, 2012 6:35 pm
    CSS PIONEER - Page 5 100_1448
    Cut four strips of 300 matt 1 inch wide and 2 inches longer than the mould,it pays to taper the end that goes in the small end of the hull as shown.
    Post  nigele(ADMIN)2 on Sat Feb 18, 2012 6:40 pm
    CSS PIONEER - Page 5 100_1449
    Extended brush I use for joining the hull halves.
    Post  nigele(ADMIN)2 on Sat Feb 18, 2012 6:49 pm
    CSS PIONEER - Page 5 100_1450
    Wet the joint in the hull with resin and the apply the joining strips dry, one at a time stipple them into place start at the large end with the strip in a u shape and slowly unroll it down the inside the hull making sure that it remains on the centre line of the joint,this is very fiddley.
    Post  nigele(ADMIN)2 on Sat Feb 18, 2012 6:55 pm
    CSS PIONEER - Page 5 100_1451
    When fully cured remove from mould and remove tape and trim up and thats it, one half of the hull done,do the same again for the second half of the hull,handy that its the same both end's.
    Post  nigele(ADMIN)2 on Sat Feb 18, 2012 7:00 pm
    CSS PIONEER - Page 5 100_1452
    A few views of the hull with the second half done.
    Post  nigele(ADMIN)2 on Sat Feb 18, 2012 7:02 pm
    CSS PIONEER - Page 5 100_1453
    Post  nigele(ADMIN)2 on Sat Feb 18, 2012 7:04 pm
    CSS PIONEER - Page 5 100_1454
    Post  nigele(ADMIN)2 on Sat Feb 18, 2012 7:06 pm
    CSS PIONEER - Page 5 100_1455
    Post  nigele(ADMIN)2 on Sat Feb 18, 2012 7:08 pm
    CSS PIONEER - Page 5 100_1456
    PS...YES DAVID, THIS IS YOUR ONE!!
    Post  Tom(ADMIN) on Sat Feb 18, 2012 7:09 pm
    Awesome work, boss...a master at his craft.
      Current date/time is Wed Apr 01, 2020 9:48 pm
