Our users have posted a total of 11072 messages in 1815 subjects
We have 839 registered users
The newest registered user is WilsonM
    Pinch valves
    Pinch valves Empty Pinch valves
    Post  david f on Mon Apr 11, 2011 1:12 pm
    I just thought I would start this topic off because it is always coming up (A perennial I think!)
    (I will post my take on the topic very soon.)
    Pinch valves Empty Re: Pinch valves
    Post  david f on Tue Apr 12, 2011 3:23 pm
    My take on the pinch valve.(Previously published in the AMS magazine.
    Works very well and is pretty small.
    Pinch valves Pinch_10
    It uses a standard servo. The aluminium extrusions can be obtained from larger B&Qs.
    The silicone rubber tubing is squashed by the internal plunger (File it to blunt V shape to improve the shut off)
    The assembly is clamped to the servo body by the brass strap. It needs to be bolted quite tight so hard solder the brass threaded rod.
    Post  Tom(ADMIN) on Tue Apr 12, 2011 3:55 pm
    Is the plunger spring loaded, David, or do you rely on the silicone tube having sufficient elasticity to release the plunger?
    Post  david f on Wed Apr 13, 2011 10:16 am
    Good question. There is plenty of bounce in the silicone rubber so no need.
    I forgot to mention that the plunger squashes the tube against the plug in the end of the square tube. The plug is epoxied or better still fixed by small self tappers. (There are quite large forces involved.)
    I have made this valve using a mini servo also (For my Holland) this works but you always need servos with high torque. (Digital ones may be good - they are getting cheaper, I notice.)
    thegrimreaper
    thegrimreaper
    Post  thegrimreaper on Wed Apr 13, 2011 1:23 pm
    Hope Chris at Sheerline dosn`t mind this but here is a picture of the Sheerline take on the pinch valve using an acrylic block with 2 holes drilled 1st hole is for the plunger 2nd hole is for the silicon tube inside the main block there are two ball bearings one either side of the silicon tube the brass plunger is pressed against the tube by the cam on the top of a ballraced servo this pinches the tube preventing the water/air from exiting the tank the cam revolves the opposite way to press the contact of the microswitch
    Pinch valves Sdc10711
    Post  Tom(ADMIN) on Wed Apr 13, 2011 2:31 pm
    I guess a pinch valve, if made with a bit of 'built in slackness' would be an ideal safety device...eventually the air would escape and the boat would surface. Or have I got that wrong?
    thegrimreaper
    thegrimreaper
    Post  thegrimreaper on Wed Apr 13, 2011 3:25 pm
    Nope thats perfectly correct Richard a small almost undesernable leak past, like a lightly dripping tap would result in the boat surfacing in the event of a problem this idea is included in the instructions from Chris of sheerline very cheep nay free failsafe
    Regards Mark
    Post  david f on Thu Apr 14, 2011 11:26 am
    Yes, that "small leak" idea is one of the clever features of the the pressure tank system, I think.
    Not that everyone likes the pressure tank idea - Nigel for one but I have just found it very good.
    As I said earlier, I incorporate reverse pumping in my system for the following reason:
    I sank my R class some years ago. I was diving it fast with the sub at quite an angle (showing off to some spectators!!) A very impressive fast dive followed by some large air bubbles and that was it - no sub!?!
    We got it back about 45 minutes later (We got the general location with the Pinger and the Chairman of the club got it off the bottom with garden rake - thank goodness for running wires! All I lost was my pride and a bottle of whisky.)
    What had happened is that the with the sub at an extreme angle I had opened the pinch valve to surface and instead of water coming out it was my air bubble.
    I now use an electronic switcher to reverse the water pump (it also controls the pinch valve) the idea being that if the sub is settled sunk but level on the bottom it can again pump water out of the tank (even pulling a vacuum) and hopefully this amount of water is enough to float the sub again.
    However, I very much like Chris's arrangement - very clean and functional.
    One other slight thing I notice with the pressure tank system is that over a long session the sub goes lower in the water. I attribute this to gradual loss of some air bubble. I occasionally take the sub out of the water and empty the tank to "recharge" the air bubble.I don't know whether any one else has noticed this?
    thegrimreaper
    thegrimreaper
    Post  thegrimreaper on Thu Apr 14, 2011 11:42 am
    I think the sub being lower in the water after extended running is possibly due to the air pressure in the tank not being enough to expel all of the water all of the time so over say 10 -15 dives/surface a little water is left in the tank after every dive and surface over the dive time the water builds up so I think taking the sub out of the water to "empty" the tank properly is a sound idea David and one that I will be taking on board form now
    Regards Mark
    Post  Tom(ADMIN) on Thu Apr 14, 2011 11:43 am
    It's a very good and very simple idea, I'm going to incorporate it into the Biber I think.
    Post  david f on Fri Apr 15, 2011 11:04 am
    Intersting that you've noticed the same effect, Mark.
    Yes, the pressure tank system has only a few snags:
    - About one third of the ballast tank space is "wasted" to provide the air space.
    - It is a pressure system so tanks need to be built and designed to cope.
    I've found that it is always worth putting baffles into the tanks too - to stop instability caused by "sloshing"
    (The free surface effect to marine engineers, I think!)
    Post  Tom(ADMIN) on Fri Apr 15, 2011 11:11 am
    How about using a bag inside the tank? That way you wouldn't need baffles, and the bag would fill up within the confines on the tank.
    Post  Tom(ADMIN) on Fri Apr 15, 2011 11:14 am
    Something like this:
    Pinch valves Dsci0017
    thegrimreaper
    thegrimreaper
    Post  thegrimreaper on Fri Apr 15, 2011 1:55 pm
    Don`t know Richard when the bag fills would it not take on the shape of the outer tank ? thus leaving an air void that would still allow slosh anyway?. I thought this idea could be used just in case of over fill or a bag burst contents of bag are contained in the tank and not through the whole WTC
    Regards Mark
    Post  Tom(ADMIN) on Fri Apr 15, 2011 3:50 pm
    The tank has three very small diameter holes drilled in the top of it, I think Nigel said to use 1/32nd inch holes, they allow the bag to fill completely to the shape of the cylinder, thus no voids.
    thegrimreaper
    thegrimreaper
    Post  thegrimreaper on Fri Apr 15, 2011 6:38 pm
    aahhh but if the bag takes on the shape of the cylinder and then only 1/2 to 3/4 fills because of the build up of air pressure you will still end up with 1/2 to 1/4 of air in the top of your cylinder for the water to slosh around in. I think ??
    Post  david f on Mon Apr 18, 2011 2:19 pm
    Call me conservative but I've never been too keen on bags.
    I've never actually used one on a sub but it is the problems of creasing them, bursting them etc.
    Put not your faith in floppy bags!
    (I think I will stick with tanks and pistons.)
    thegrimreaper
    thegrimreaper
    Post  thegrimreaper on Wed Apr 20, 2011 8:43 am
    I have heard of guys using swimming arm bands which personally I think is a bit dodgy but also heard of blood pressure cuffs being used now having to use a pressure cuff to do my blood pressure every day they can hold a lot of pressure and are quiet long lasting when being filled with air I know water is a totally different medium I think if for space reasons I had to use one as an alternative means of floating my boat then that would be the way to go also as we all know building a submarine is not cheap and looking at the price difference 1X large blood pressure cuff £9.99 against 1X piston tank and associated electronics about £100(??) for me it would have to be the cheaper option
    Regards Mark
    Post  Tom(ADMIN) on Wed Apr 20, 2011 9:08 am
    You used to be able to buy purpose made air bags for model subs...SHG Marine, I think it was, did them, they came in various sizes and always in an awful orangey/redish colour. John Darnell always supplied them in his kits.
    I've just googled SHG and I can't seem to find them on their website, so maybe they don't supply them any more.
    Post  Tom(ADMIN) on Wed Apr 20, 2011 9:12 am
    Aha...just found that this guy does ballast bags, amongst other things. Worth a look round his Ebay shop.
    http://stores.ebay.com/rcsubworkshop
    Post  david f on Wed Apr 20, 2011 4:17 pm
    You are not convincing me either of you!
    Crinkly bags - no way!
    Post  Tom(ADMIN) on Wed Apr 20, 2011 4:39 pm
    You'd be amazed how strong they are David...try filling a common or garden balloon with water. It swells to a ginormous size before bursting. Now fill a rugby ball bladder...you'll not burst that!
    gantu
    gantu
    Post  gantu on Wed Apr 20, 2011 6:13 pm
    Pinch valves 20mnn9_111
    Post  david f on Thu Apr 21, 2011 10:01 am
    Hi Gantu,
    That looks very good.
    It is interesting how many different variations there are on pinch valves.
    gantu
    gantu
    Post  gantu on Thu Apr 21, 2011 5:20 pm
    Hi david,
    this is one kind from an friend he build this one and yes there some ways to do this.
      Current date/time is Fri Feb 28, 2020 11:24 pm
