I was going to install a 12v 4.5a/h gel cell up in the bows, but it didn't fit (grrr!) so I've ordered a 12volt 3700a/h nicad pack specially made to fit the space available.
Flood holes are drilled, shaft is temporarily fitted, so next job is to make a start on the detailing of the conning tower, finish off the 'scopes, and then make up the few bits on the deck.
I think I've worked out how to release the torpedoes, but that entails much brass work, so there's a job for my tame engineer. A friend in Bristol is getting the metal work that supports the rudder and rear dive plane made up for me, and as you know, Alfie is going to make the torpedoes operational.
Without the help of Alfie, Andrew Gray and his friend Terry, Dave at ACTion Electronics, Kevin Coombs, Ramesh, Andy Lawrence, Andy Oakley, and the two Paul's...Cook and Holman, I wouldn't have even got this far with the build...I thank you all for your advice, assistance and hard work on my behalf.
» Alexander Engel Russian typhoon Submarine
» Norwich Submariners joint Model Boat weekend - 27/28th July 2019
» Revell 1:144 212A Conversion
» Model Boats Magazine, March 2019 Issue
» Papplewick Pumping Station, 21, 22nd April
» Norwich Sub Weekend - THANK YOU, Paul!
» 3d printed Alfa Class Russian Submarine
» HMCS CC-2 Canadian submarine from 1914 - Scratch built in 1:48 scale
