I've just found in my spares box a Sub Tech "SBS-2 Prop Shaft Stuffing Box with seals"...it seems to be a length of brass tube about 2" long with bronze bushes either end, and two internal O ring seals. According to the brief instructions, it must be fitted in one way only, which is described on the packet.
I'm guessing it would take a 1/4" prop shaft, which I could then connect to the stub shaft by using a standard Huco type coupling.
I take it that this can be fitted into the end cap of a wtc, with the prop shaft passing through it to make a water tight seal?
Anyone ever used one of these?
Last edited by Richard(Admin) on Sat Mar 05, 2011 10:22 am; edited 1 time in total (Reason for editing : Image added)
