Grantham MBC, SUN, AUG 11 AT 10 AM
fore and aft diving vanes EmptyYesterday at 1:16 am by merriman
fore and aft diving vanes EmptyTue Apr 23, 2019 2:52 pm by david f
» Eden Dynamic WTC
fore and aft diving vanes EmptyFri Apr 19, 2019 3:20 pm by Deepdive
» John Lambert Plans
fore and aft diving vanes EmptyMon Apr 15, 2019 2:27 pm by david f
» Telemetry on openLRS
fore and aft diving vanes EmptyMon Apr 15, 2019 2:23 pm by david f
» Assisting with a 1/96 NOVEMBER class kit
fore and aft diving vanes EmptyWed Apr 03, 2019 12:36 pm by merriman
» trimming 1/96 USS ALBACORE
fore and aft diving vanes EmptySat Mar 23, 2019 12:37 am by merriman
fore and aft diving vanes EmptyFri Mar 22, 2019 2:37 pm by tsenecal
» Piston Ballast Systems
fore and aft diving vanes EmptyWed Mar 20, 2019 12:16 am by merriman
Our users have posted a total of 10825 messages in 1774 subjects
We have 803 registered users
The newest registered user is yangshexiang
      Brian Adley
      fore and aft diving vanes Empty fore and aft diving vanes
      Post  Brian Adley on Tue Aug 09, 2016 9:54 am
      I have an Albacore model submarine which I have not used in a number of years now and want to get back to it. The model has aft diving planes only and I want to add forward diving planes. My question is: do the planes interact in such a way as to push the bows down while pushing the stern up (and visa versa), or do both fore and aft planes push the bows and the stern in the same direction? I rather fancy using them to push the bows and stern in the same direction in order to keep the submarine horizontal at all times. Can anyone give me some advice please? Thanks. Brian
      fore and aft diving vanes Empty Re: fore and aft diving vanes
      Post  Hermann on Tue Aug 09, 2016 1:11 pm
      Hello Brian,
      the effect depents on the relationship between the control of the fore and aft diving planes.
      When they are controlled in a manner to be parallel to each other (e.g. both front edges tilted down) the dynamic force will act on the bow section and the stern section in the same way and your model will descent or ascent on more or less even keel. The residual inclination will depend upon th ebalance between the fore and aft planes.
      When operated with contrary control (e.g. the bow planes point down and the aft planes point up) the inclination of your model will be even greater compared to the use of the aft planes only.
      Fore planes will give some benefit when submerging from the surface. With action of the aft planes only (with the front edges oft aft planes tilted up) the stern will be lifted to make the bow point downwards. With some models it can happen that the propeller comes partially out of the water, this will reduce the propulsion effect. With support of the fore planes operated contrary (their front edges pointing down) the bow is forced down by the dynamic force and this will help to submerge better.
      If possible with your radio control it would be useful to programme your transmitter in a manner to select between the two operation modes parallel action and contrary action of the fore and aft planes by means of a switch.
      kind regards
      Klaus-Dieter
      Post  merriman on Tue Aug 09, 2016 2:25 pm
      Brian Adley wrote:I have an Albacore model submarine which I have not used in a number of years now and want to get back to it.  The model has aft diving planes only and I want to add forward diving planes. My question is: do the planes interact in such a way as to push the bows down while pushing the stern up (and visa versa), or do both fore and aft planes push the bows and the stern in the same direction? I rather fancy using them to push the bows and stern in the same direction in order to keep the submarine horizontal at all times. Can anyone give me some advice please? Thanks. Brian
      Keep the bow and stern planes on separate channels. Let the angle-keeper tend the stern planes. You drive the bow planes for depth control.
      No one on this planet has assembled and operated more 1/60 ALBACORES than me. As with most submarines the stern planes of the ALBACORE have the long moment arm to effect angle changes to the boat. The bow planes don't, so they dynamically pull the boat up or down (they do have a pitch moment, but no where the magnitude of the stern planes). If you're transmitter is smart enough to provide channel mixing then go ahead and dial in about 10% coupling between the two horizontal control surfaces -- collectively, not differentially!
      Do not mechanically couple the bow and stern plane linkages to free up a channel -- that's a fools errand as the boat will only work well at one specific speed and depth, but will be a wild pony ride in all other situations.
      fore and aft diving vanes 001_ygp22BD
      fore and aft diving vanes DSCF4032
      https://s262.photobucket.com/user/dmeriman/slideshow/albacore
      Here's how the boat works when you do it as I describe:
      https://www.youtube.com/watch?v=G53StePB0RY
      https://www.youtube.com/watch?v=DhAG-7W_5kA
      https://www.youtube.com/watch?v=TSr41K5Uaj4
      https://www.youtube.com/watch?v=3RnfxJINK3U
      https://www.youtube.com/watch?v=7uvc6jtU2cM
      Brian Adley
      Post  Brian Adley on Wed Aug 10, 2016 4:53 pm
      Thank you folks. I was about to make some mistakes by the looks of it as I was going to link the fore and aft planes together on the same servo. Not sure where the additional servo will go if they are individually controlled but that's to be investigated. I see from the photos that the linkage to the forward planes seems to go through the rear of the pressure hull. I was going to take it through the front by means of a flexible linkage over the top of the ballast tank. More to think about. Brian
        Current date/time is Thu Apr 25, 2019 3:39 am
