Piston cylinder EmptyFri Mar 15, 2024 4:36 pm by david f
Piston cylinder EmptyTue Mar 12, 2024 1:56 pm by geofrancis
Piston cylinder EmptySun Mar 10, 2024 6:30 pm by cat
Piston cylinder EmptyWed Mar 06, 2024 4:50 pm by tsenecal
Piston cylinder EmptyMon Feb 19, 2024 9:24 pm by Michaelc
Piston cylinder EmptyThu Feb 15, 2024 1:53 pm by david f
» Engel Nautlus
Piston cylinder EmptyTue Feb 13, 2024 9:15 am by palmert6
» RF 27/433MHz maximum depth in pools (1-5 ppm chlorine, 6-8pH)
Piston cylinder EmptyThu Feb 08, 2024 2:05 pm by david f
Piston cylinder EmptyThu Feb 08, 2024 1:37 pm by david f
We have 1005 registered users
    Piston cylinder
    Kevin D
    Piston cylinder Empty Piston cylinder
    Post  Kevin D Sat Jan 03, 2015 2:42 pm
    Just received my piston cylinder from Donald (RC Sub Workshop) I'm really looking forward to experimenting with this and  impressed with the build quality. Has anyone used one of these?
    Once I get round to using this I'll post a reveiw, it's turning out to be a busy building season !!!!
    Piston cylinder Dscn0110
    Piston cylinder Dscn0111
    Piston cylinder Dscn0112
    Piston cylinder Empty Re: Piston cylinder
    Post  salmon Sat Jan 03, 2015 7:03 pm
    I am looking forward to what you find! It looks like a nice unit.
    Post  david f Mon Jan 05, 2015 9:59 am
    Looks like a very nice piece of kit. I particularty like the microswitch arrangements.
    Does it use an O ring piston seal or a lip type - both seem to be commonly used?
    Post  John Wrennall Sun Jan 11, 2015 9:45 am
    Excellent looking tank, Love those chunky diodes.
    What is the purpose of the 8 end cap holes?
    I assume the Gear reduction is internal, that would be very interesting to see
    if(when) you take the covers off.
    Kevin D
    Post  Kevin D Sun Jan 11, 2015 4:40 pm
    The piston seal is an O ring.
    As far as I am aware the 8 holes are just for mounting the tank in the WTC. The gear reduction is external and can just be seen between the end cap and motor.
    Kevin
      Current date/time is Thu Mar 28, 2024 1:28 pm
