In total there are 4 users online :: 0 Registered, 0 Hidden and 4 Guests :: 1 Bot
» today's work
HM Submarine No 1 (The Holland) - Re-visited EmptyToday at 9:23 pm by merriman
» 3D printed sub kits
HM Submarine No 1 (The Holland) - Re-visited EmptyYesterday at 8:34 am by Deep Diver (Fred)
» RC for Submarines
HM Submarine No 1 (The Holland) - Re-visited EmptyYesterday at 5:54 am by tsenecal
HM Submarine No 1 (The Holland) - Re-visited EmptyTue Mar 24, 2020 11:27 am by david f
» Telemetry on openLRS
HM Submarine No 1 (The Holland) - Re-visited EmptyMon Mar 23, 2020 1:21 pm by david f
» stretching sprue
HM Submarine No 1 (The Holland) - Re-visited EmptyThu Mar 12, 2020 1:13 pm by merriman
HM Submarine No 1 (The Holland) - Re-visited EmptyThu Mar 05, 2020 2:30 pm by david f
HM Submarine No 1 (The Holland) - Re-visited EmptyWed Feb 26, 2020 10:30 am by david f
HM Submarine No 1 (The Holland) - Re-visited EmptyMon Feb 17, 2020 11:10 pm by C-3PO
Our users have posted a total of 11099 messages in 1818 subjects
We have 845 registered users
    HM Submarine No 1 (The Holland) - Re-visited Empty HM Submarine No 1 (The Holland) - Re-visited
    Post  david f on Sat Feb 28, 2015 10:58 am
    This article was written in June 2011 and published in the AMS magazine shortly afterwards. I have recently been doing a little bit of refurbishment, and so it seemed like a good moment to start this thread.
    The original article follows and I will publish the update next Saturday:
    HM Submarine No 1 (The Holland) - Re-visited 344110
    HM Submarine No 1 (The Holland) - Re-visited Britai10
    I like to build British submarines built in (or close to) Barrow in Furness. (The modeling world has enough U boats!) So my little fleet of an R Class and Resurgam 2 and a Holland all fit the bill.
    Holland 1 is especially important since she was built in Barrow (under great secrecy) and was the RN’s first submarine. Some of you may remind us that she was built to an American design of the Irish/American genius John Holland. Well yes, but she is quite different in deck shape to the US ones and our own very resourceful Captain Bacon added lots of extra features such as the periscope. His early periscope used to invert the image when you looked astern!
    What is also nice is that the Hollands (all 5 of them) didn’t kill anyone of any side. The ultimate deterrent.
    Holland 1 herself sank off the Eddystone on the way to the breakers in 1913 but was recovered in 1981 and can be seen today at the RN Submarine museum, Gosport. I have many photos and the museum staffs were immensely helpful.
    For the model, I was very impressed by Nigel Edmond’s Holland 2 (Which has now sadly been sold on several times and has ended up gathering dust in a less than good home!) Nigel had made the fiberglass version from a fragile ply model which had been provided by Fred Ellis. Steve Webb had started work on one of Nigel’s mouldings before his death and I would like to thank Dianne Webb for agreeing to sell the unfinished model.
    Nigel's model:
    HM Submarine No 1 (The Holland) - Re-visited 100_0110
    HM Submarine No 1 (The Holland) - Re-visited 100_0111
    Steve had started work on an aluminium bayonet type hull closure which used a vertical split about 1/3 of the way up from the stern.
    Nigel used a similar arrangement with a buoyancy bag system and he also strongly recommended the use of a sliding weight trim system using the batteries.
    However I prefer the pumped pressure tank system and I intended to use Lipo batteries for the first time which are a bit light to use as a moving weight.
    So some initial sketches (By the shores of Lake Como as it happened until Avril reminded me we were on holiday!) suggested that:
    The pressure tank should be circular and a lead trim weight could be “wrapped round” it and operated by a mini servo.
    The pressure tank “wastes” about ½ to 1/3 of the tank volume because of the compressed air bubble and so fitting everything into to such a small and elongated egg shape would be very difficult.
    The use of a WTC would waste too much space.
    On returning home, I filled the 2 hull sections up with water and found that displacement was about 3.75 liters.
    I estimated that the ballast tank volume should be about 10% of this which gave a water fill of 375 ml.
    A 140 mm length of  68mm diameter PVC gutter pipe fitted well in the hull (Have I said how much I like PVC pipe!) I made the ballast tank by making 2 PVC end caps for the tube and fitted a single brass pipe for water inlet and outlet. The tank was glued together and leak tested and then coated with 3 layers of glass matt and resin to allow it to stand the pressure.
    HM Submarine No 1 (The Holland) - Re-visited Img_0510
    That was OK so far but the next thing was the bayonet sealing ring and sealing the shafts for the control surfaces (No WTC possible.) The shaft seals were sorted quickly – O rings inside a brass tube glassed into the hull – reliable on a test setup.
    The bayonet rings were trickier. The ones that Steve had made were designed for the hull cut near the stern and were quite sturdy. The net result was that fitting things in to the hull was like getting a ship in a bottle, if you see what I mean. So it had to be a hull division in the centre at the widest point.
    Back to PVC sewer pipe – and an experiment. Take a piece of 110mm pipe and cut lengthwise slices a few mm wide lengthwise until it can just be pushed into a piece of 4” pipe. When it does, glue the cut together with PVC cement and then glue this into a piece of 4” pipe.
    Fix this on a lathe faceplate (Not very easy because it is quite flexible.) Take a skim cut. Cut a groove around this piece. Insert a 2mm cross section O ring . Grease it and push into other piece of sewer pipe. Leak test. It seals again and again!  Result a slim line bayonet fitting which costs about 20p!
    The next problem was that the hull needed to be cut in the centre and my new bayonet ring diameter is a little bit big to fit in the existing hull. The simplest thing to do was to actually make a new hull cast from the old one.
    So I made a female mould and then made 2 male moulds. I glassed them together with 2 pieces of PVC pipe inserted (See photo) The smaller diameter piece was to make it easier to insert PVC bow and end caps. The PVC pipes were covered with pva release agent.
    HM Submarine No 1 (The Holland) - Re-visited Pictur10
    Once everything had cured, I cut the whole thing in half and glassed the inside hull seams. I then removed all the pieces of PVC pipe.
    I then started to fit the hull out. The bow was easy – a solid PVC plug with a hole for a nylon pipe to allow water to be pumped in and out of the ballast tank. The torpedo tube hatch would eventually cover this.
    I fixed my PVC bayonet fitting into the centre section with silicone rubber.
    The stern cap was drilled for a 4mm stainless steel prop shaft. The shaft was sealed with a Simrit seal with a ball race on the dry side.
    The drive motor was a multi-pole Buhler motor from Model Motors Direct with a 3 to 1 gear reduction (Graupner gears.)
    My attention then turned to the sliding weight system which Nigel had recommended.
    There is a useful formula in Norbert Bruggen’s book which enables you to calculate the effect of this. This showed that a “wrap around” weight on the ballast tank would give a useful pitch change from a typical servo throw. (See photo) The weight slides on PTFE blocks to reduce friction and the photo also shows the spring system to avoid servo damage if you hit something.
    The next thing was to fit everything in – difficult with much trial and error!
    One extra complication was that the Pinger had to work from inside the submarine. There was no free flooding area on this submarine. I bonded a piezo ceramic transducer to the inside hull at the stern and this was plugged into a modified Pinger.
    The assembly for the rudder and hydroplanes was a little tricky to visualize from the drawings and I made it up from sheet PVC. The rudder and planes were made from polycarbonate.
    The prop was also a problem because there is nothing like it available commercially – it is a large disk with small blades. I knew this was going to be a trial and error job. So I mocked one up from an aluminium disk with slits cut in it and stuck some twisted pieces of aluminium in with Evostik. It lasted long enough to tell me whether it would work or not!
    Initial ballasting was done in the bath and it was found that the sliding weight system worked very nicely. You can make the Holland nod and bow!
    Lots of pond tests at the Barrow in Furness MBC followed. A lot of experiments went into the prop to get a reasonable model speed. The blade area and pitch were increased and the prop was eventually made of brass with brass blades soft soldered.
    The crowning achievement was the weekend display at the RNSM, Gosport and the photo of the model in front of the real one.
    She is a very nice little sub to maintain and operate and always attracts interest at the pond side.
    Oh and the original hull is still available (and it includes the superstructure moulding) to a "good" home i.e an AMS  member who will actually build something and donate £50 to the AMS.
    Next installment next Saturday.
    HM Submarine No 1 (The Holland) - Re-visited Dg54210
    HM Submarine No 1 (The Holland) - Re-visited Dsc_0410
    HM Submarine No 1 (The Holland) - Re-visited Hollan10
    HM Submarine No 1 (The Holland) - Re-visited Img_0110
    HM Submarine No 1 (The Holland) - Re-visited Img_0211
    HM Submarine No 1 (The Holland) - Re-visited Img_0212
    HM Submarine No 1 (The Holland) - Re-visited Img_0213
    HM Submarine No 1 (The Holland) - Re-visited Img_0216
    HM Submarine No 1 (The Holland) - Re-visited Img_0218
    HM Submarine No 1 (The Holland) - Re-visited N7342710
    HM Submarine No 1 (The Holland) - Re-visited Pq1_df10 [/quote]
    HM Submarine No 1 (The Holland) - Re-visited Empty Re: HM Submarine No 1 (The Holland) - Re-visited
    Post  salmon on Mon Mar 02, 2015 3:51 am
    Very nice article! Thank you for posting this.
    Post  david f on Sat Mar 07, 2015 8:15 am
    Some feedback on the first article. Nigel tells me that his model was a Holland 2 not a 4 and the photo says so! (Now amended.)
    As I said before, the sub has given several years of good service but a couple of problems have emerged:
    - It is a little leaky! Leak testing with air shows that it is not the plastic connection but the bond between the plastic pipe and the fibreglass. (Dropping the sub a couple of times has probably not helped!) I thought that re-making the joint would help and that making the plastic inner in aluminium would be stiffer in use and easier to hold in the lathe.
    - Everything is a very tight fit. I am wondering about putting in a piston tank. (Less wasted volume compared with a pressure tank.) Putting in a brushless motor would also save space but the existing brushed motor is working well.
    I didn't want to start machining large blocks of aluminium but an ebay search gave the following:
    Aluminium Round Tube 50mm 55mm 57mm 63mm 65mm 70mm 75mm 100mm 165mm 2" 3" 4"
    Outside Dia x Wall Thickness: 4" x 10swg (101.6mm x 3.25mm)
    Length: 400mm
    Estimated delivery Fri, 23 Jan - Tue, 27 Jan
    ITEM PRICE:
    £14.20
    The outside diameter was not quite ideal in that the gap between it and standard sewer pipe was about a mm. But the O ring seems able to take this up.
    The next three photos show the pipe being chucked in my trusty Peatol (Taig) lathe. Not easy to fix true so a lot of trial and error being made.
    The next three photos show this and the machined groove for a 3mm O ring.
    HM Submarine No 1 (The Holland) - Re-visited Img_4316
    HM Submarine No 1 (The Holland) - Re-visited Img_4318
    HM Submarine No 1 (The Holland) - Re-visited Img_4317
    To reduce any problems with the O ring being dragged out of it's groove, I chamfered the edge of the plastic pipe.
    The original coupling had been bonded into the glassfibre with silicone aquarium sealant - high modulus. I redid the joint with silicone (pvc window) sealant also high modulus.
    This time I was more generous with the sealant and also fixed the ring in with 4 self tapping screws.
    This joint is 100% airtight in tank tests but has not yet been tested with the sub in operation. (I will let you know how it works out.)
    It is a useful addition to my range of "things to do with plastic sewer pipe"!
    More to come on the Holland refurb over the next few months.
    HM Submarine No 1 (The Holland) - Re-visited Img_4321
    HM Submarine No 1 (The Holland) - Re-visited Img_4322
    HM Submarine No 1 (The Holland) - Re-visited Img_4323
    HM Submarine No 1 (The Holland) - Re-visited Img_4410
    HM Submarine No 1 (The Holland) - Re-visited Img_4411
    While I had the lathe out I also prepared some aluminium tube for my new (mid-size) piston tank. (The inner bore has a much better finish than the outer surface!)
    HM Submarine No 1 (The Holland) - Re-visited Img_4319
    HM Submarine No 1 (The Holland) - Re-visited Img_4320
    bwi
    bwi
    Post  bwi on Sat Mar 07, 2015 9:30 am
    Pretty amazing stuff David……especially the picture were you manage to clamp the alu pipe onto the lath……fine example of “persistence”.
    grtz,
    Bart
    Post  david f on Sun Apr 19, 2015 3:35 pm
    The Holland went back into the water today but as an unpowered test bed for the 458Mhz system (see my other post.)
    But her "airing" or "watering" showed a couple of things:
    - The new aluminium sealing ring works and seals nicely in 4 feet of water.
    - My small proportional piston tank will be fine as a ballast tank. (It only pumps about 65ml of water but this is OK for the minimal superstructure of the Holland.)
    While I am doing this re-furb I think I will also put an Mtroniks brushless motor in to free up some space in the stern.
    Post  david f on Sat May 09, 2015 9:44 am
    Rushing to get this ready for the start of the season!
    So a test at the pond  showed a list of good and bad things:
    Good
    - The aluminium sealing ring is nice and watertight.
    - The new Mtroniks Hydra brushless combo (the second sub I have re-fitted) is really nice. Good range of control and super torque for big (scale) props. Also a very good space saver in this tight hull even with the 3:1 toothed belt reduction.
    - My weight shifting servo got its gears stripped - despite protection springs. (I think I may re-assess this shifting weight trim adjustment system.)
    Bad
    - The small piston tank is not really good enough to get a decent waterline. 65ml is too little. I think I will rebuild the piston tank with the 50mm OD tube I have used in the middle sized piston tank. A 40mm diameter is too small (volume goes up as the square of the diameter.)
    - I seem to be suffering short range with the 458 Mhz setup - only about 100 feet. My new short aerial or screening from the aluminium sealing ring?
    So all in all the re-fitted Holland is going to have to go on the "back burner" until Norwich.
      Current date/time is Wed Apr 01, 2020 10:10 pm
