Grantham MBC, SUN, AUG 11 AT 10 AM
Darnell RN S class plans - Page 2 EmptyToday at 1:16 am by merriman
Darnell RN S class plans - Page 2 EmptyYesterday at 2:52 pm by david f
» Eden Dynamic WTC
Darnell RN S class plans - Page 2 EmptyFri Apr 19, 2019 3:20 pm by Deepdive
» John Lambert Plans
Darnell RN S class plans - Page 2 EmptyMon Apr 15, 2019 2:27 pm by david f
» Telemetry on openLRS
Darnell RN S class plans - Page 2 EmptyMon Apr 15, 2019 2:23 pm by david f
» Assisting with a 1/96 NOVEMBER class kit
Darnell RN S class plans - Page 2 EmptyWed Apr 03, 2019 12:36 pm by merriman
» trimming 1/96 USS ALBACORE
Darnell RN S class plans - Page 2 EmptySat Mar 23, 2019 12:37 am by merriman
Darnell RN S class plans - Page 2 EmptyFri Mar 22, 2019 2:37 pm by tsenecal
» Piston Ballast Systems
Darnell RN S class plans - Page 2 EmptyWed Mar 20, 2019 12:16 am by merriman
Our users have posted a total of 10825 messages in 1774 subjects
We have 803 registered users
The newest registered user is yangshexiang
    dgp1957
    Darnell RN S class plans - Page 2 Empty Re: Darnell RN S class plans
    Post  dgp1957 on Tue Sep 30, 2014 1:23 pm
    Post  John Wrennall on Tue Sep 30, 2014 8:23 pm
    Hi David.
    Are you going to Blank off the  fitting on the bottle side to give a pressurised tank
    OR set the tank up as a vented system?
    If the former, then check that the thread is sufficient to withstand pressure.
    500cc with a pressure system = 300cc actual (say) which is 300gms weight,
    will this be enough to overcome the boats buoyancy?
    regards
    Post  david f on Thu Oct 02, 2014 9:55 am
    Hi David, I don't think that tank could stand the pressure (about 300 KPa or 3 atmosphere) if you want to use the pressure tank system. It is a very good question so I have just started a thread on pressure ballast tanks in the Beginners section.
    Post  John Wrennall on Thu Oct 02, 2014 4:34 pm
    You might find this installation amusing but it works reliably.
    The 150cc home made clunk tank is filled with a lorry windscreen pump (24v running on 12V) and the capacity is enough for a static dive. The air from the tank is displaced into a normal rubber balloon which helps to evacuate the water later and keeps the water from entering the WTC.
    The balloon should be as thick as possible for safety, get mine from a party balloon shop.
    Its due for renewal before the next sailing season.
    I will stress that this is used in my first sub (over 10 years ago) when I didn't know any difference.
    Darnell RN S class plans - Page 2 Img_0521
    Darnell RN S class plans - Page 2 Img_0522
    Darnell RN S class plans - Page 2 Img_0523
    Darnell RN S class plans - Page 2 Img_0524
    John.
    Post  david f on Fri Oct 03, 2014 5:51 pm
    Nice one John! I think I like that best of all the "baggy" & "bladdery" solutions. It will pressurise the WTC though and how do you stop the balloon from bursting if you run the pump for too long?
    Post  John Wrennall on Fri Oct 03, 2014 7:40 pm
    easy peasy, the balloon is inserted into a toilet roll tube (not shown in photo) which gives it a physical dimensional restraint to about the size of a conference pear which does not create too much of a WTC pressure. The boat is ballasted to dive with the tank 2/3 full so pump is switched off via the old Mk1 Eyeball system and the compressed air does give a fail safe effect.
    I do recollect that the balloon would not have been used if I had found a bigger bottle.
      Current date/time is Wed Apr 24, 2019 5:39 pm
