Our users have posted a total of 11050 messages in 1811 subjects
We have 835 registered users
The newest registered user is CADArtist1965
    LOS ANGELES build logs
    LOS ANGELES build logs Empty LOS ANGELES build logs
    Post  profesorul on Wed Feb 05, 2014 9:05 pm
    HELLO ALL ,
    Be ADVICE : Is gonna be a very long thread so PLEASE have patience !
    Earlier this week I took courage and I start working on these project .
    That is a LOS ANGELES submarine bought it from someone on the forum .
    - I started with rudders depth as required for the large volume of Sisyphus work ....
    - after many, many hours of sanding an file I managed to do what you can see in the pictures...
    HOW TO FIX :
    1) file until get same length?
    2) fill until get same length ?
    LOS ANGELES build logs Differ12
    LOS ANGELES build logs Differ13
    - then continued with bow rudders ....NO problems here ,
    - with tower is another story and I have some questions about the place to put axis for Bow Rudders ....( see pictures )
    LOS ANGELES build logs Ax11
    - I do not know what those two parts are and which should be put it ( see pictures )
    LOS ANGELES build logs Corect11
    and the last question from these series :
    1) what are those holes and witch should be drilled ( I think some of them should be don do the captive air !)
    LOS ANGELES build logs Holes11
    LOS ANGELES build logs Dive_r11
    LOS ANGELES build logs Stern_10
    OK for now,
    THANK YOU
    LOS ANGELES build logs Empty Re: LOS ANGELES build logs
    Post  profesorul on Fri Feb 07, 2014 9:40 am
    For the moment all I have is these :
    LOS ANGELES build logs Img_0210
    LOS ANGELES build logs Img_0211
    LOS ANGELES build logs Img_0212
    LOS ANGELES build logs Img_0213
    LOS ANGELES build logs Wtc_ar10
    - any suggestion about Reliable Speed Controller ......Fail Safe devices and what else should be ?
    - the RC is FUTABA 6EXP - 6 channels (4 + 2 ) ,40MHz .
    I know is an very old model but that's gonna be do the small budget
    Cam on don't be shy !
    Post  profesorul on Tue Feb 11, 2014 3:59 pm
    No idea nobody?.....hmmm.
    Post  Tom(ADMIN) on Thu Feb 13, 2014 4:18 pm
    Marius, apologies for not answering your post, I haven't been too good recently.
    I'll post up some pics tomorrow of how I did mine...
    Post  profesorul on Wed Feb 26, 2014 10:19 am
    RICHARD , IS NO NEED to APOLOGIES my Friend , last time when I checked "was a Forum not a Marriage" (laughing)
    How are you filling these days ?......I hope You are in Good Shape .
    Did You get the time to find some pictures with Your LA sub ?.
    QUESTION:
    I found these Water Pump on eBay
    http://www.ebay.com/itm/WATER-PUMP-Electric-6v-12v-rc-model-boat-Robbe-p-/120777343795#ht_1961wt_867
    can be used to Fill/Empty a ballast tank for my LA sub ?.....is necessary to have a speed controller for it?.....how about the price/seller?.
    My intention is to buy 2 pieces , one for these project and one for spare for another project .
    Post  Tom(ADMIN) on Wed Feb 26, 2014 10:50 am
    That water pump will be fine, Marius...it's reversible, so you can fill/empty your ballast tank with it.
    You can either use a speed controller or a pair of microswitches on a servo to operate it, I use microswitches...easier to install and a lot cheaper too.
    Have a look at the Skipjack build log for information as to how to install your dive planes, it's practically identical in the way it's set up.
    Post  profesorul on Thu Feb 27, 2014 9:54 am
    THANK YOU ,
    I like the idea to use microswitches .
    Any recommendation for : what type/brand ?........I don't know how much Amps will draw the pump ?
    Looking throw Your SKIPJACK thread I found these picture and I have a couple of these around here somewhere (deep down In a closet !) , I suppose I can use them right ?
    LOS ANGELES build logs Wtc_co11
    Post  Tom(ADMIN) on Thu Feb 27, 2014 10:32 am
    They will be fine for your water pump, Marius...I've used them for all sorts of things and never burnt one out yet.
    Post  profesorul on Thu Feb 27, 2014 8:56 pm
    OK , THANKS .
    Post  profesorul on Thu Mar 06, 2014 12:02 pm
    HI ,
    To day I am very glad because I did some progress on the project.I know is NOT very much but when You don't have SPARE time at all and Your work shop is the kitchen and work bench is kitchen table - IF YOU GET THE PERMISSION from "MASTER CHEF" my WIFE !!!  is A PROGRESS .
    Couple days a go I glued a piece of PVC sheet on both Dive Planes . I din't have to file them to shape .
    LOS ANGELES build logs Img_0214
    LOS ANGELES build logs Img_0215
    LOS ANGELES build logs Img_0216
    Yesterday and to day I did the Motor mount from a small piece of aluminum sheet .
    It was necessary to Drill , cut , tap , file .
    Doesn't look much but I keep the tools in to a small crowded closet , some of them on balcony , where is my lathe too !!! .
    When I tray to do something it need 30min to get the tool down and another 30min - 40min to clean the work place .
    I told You all these to see way is gonna be a very long thread plus the "dam found" always missing !.
    LOS ANGELES build logs Img_0217
    LOS ANGELES build logs Img_0218
    LOS ANGELES build logs Img_0220
    LOS ANGELES build logs Img_0221
    LOS ANGELES build logs Img_0222
    LOS ANGELES build logs Img_0223
    LOS ANGELES build logs Img_0224
    See You soon..... I HOPE .
    All the Best,
    Post  profesorul on Mon Mar 10, 2014 11:38 am
    HI ,
    Regarding some Advices  I did some Work on NEW Motor Mount , and these is the Result:
    LOS ANGELES build logs New_mo11
    LOS ANGELES build logs New_mo10
    LOS ANGELES build logs New_mo12
    LOS ANGELES build logs New_mo13
    LOS ANGELES build logs New_mo14
    Here I encountered a small Problem solved by cutting some material :
    LOS ANGELES build logs New_mo15
    LOS ANGELES build logs New_mo16
    LOS ANGELES build logs New_mo17
    LOS ANGELES build logs New_mo18
    LOS ANGELES build logs New_mo19
    LOS ANGELES build logs New_mo20
    All the Best and CLEAR WATERS
    Post  Tom(ADMIN) on Mon Mar 10, 2014 4:45 pm
    Coming along nicely, Marius...I like the motor mount, very ingenious.
    Post  profesorul on Mon Mar 10, 2014 7:37 pm
    THANKS RICHARD ,
    Very Slowly !. NO spare time !.
    Post  profesorul on Fri Mar 14, 2014 10:47 am
    HI GUYS ,
    I did some work to day. Is not exactly " a piece of art" but is Hand Made , my HANDS ! so is perfect . I am joking of course . If there are some aspect witch can be improved be Free to tel me .
    What I did today is actually 2 small bronze pieces , for rods control of rudders and dive planes . (I KNOW here is not quite Good English Grammatic  !!!).
    LOS ANGELES build logs 01_15
    LOS ANGELES build logs 02_15
    LOS ANGELES build logs 03_15
    LOS ANGELES build logs 04_15
    LOS ANGELES build logs 05_15
    All The Best and CLEAR WATERS
    Post  tattooed on Fri Mar 14, 2014 7:04 pm
    very nice marius very nice indeed
    Post  Tom(ADMIN) on Fri Mar 14, 2014 7:16 pm
    Looking good Marius...looking good.
    Post  profesorul on Fri Mar 14, 2014 7:34 pm
    My intentions are to AVOID the O-rings on push rodes . Do you think is possible to use around the push rodes only grease to stop water go inside ??? . I don't have space for the O-ring inside those pieces .
    Post  profesorul on Sat Mar 15, 2014 6:20 pm
    HI there ,
    I did some progress to day . I made the propeller shaft house . I don't know if is going to be the final , that's hard to say now . Wheel shall see . Any way these cames out after a 3 - 4 hours of hard work  . Way take so much , is because I was going in just 0,010mm too MUCH  and the Ball Bearing wasn't going as is should be . You now what I mean . I HAVE MY LIMITS !!!. I don't have the skills and the technick to do that kind of work from the first time . On the 3rd TIME It was Good Anough to give hem a shot .
    Any tips/tricks/ would be great for those kind of operation in a very close future .
    LOS ANGELES build logs 01_1510
    .A = Hight for the Ball Bearing ; B = hight for the Simmering . You can see way was a Little difficult to succeed from the first tray .
    LOS ANGELES build logs 02_1510
    LOS ANGELES build logs 03_1510
    My expectation is to be both the Rod Guides and sealing at the same time . I wheel tray to make as tight as possible the hole for the rod and with some good White Grease to manage to seal .
    Do You think is gonna be possible ?.
    I forget to mention the Rod Guides is going to be attached to Rubber Push Rod Seal (similar to these ):
    LOS ANGELES build logs Bellow10
    Post  profesorul on Tue Mar 18, 2014 8:09 pm
    That's my latest work :
    LOS ANGELES build logs ><a href= LOS ANGELES build logs WTC_Propeller_Shaft_0"
    LOS ANGELES build logs WTC_Propeller_Shaft_1
    LOS ANGELES build logs WTC_Propeller_Shaft_2
    P.S I ordered 2x15A MARINE VIPER/Mtronik Speed Controllers .
    LOS ANGELES build logs Viperm11
    Post  profesorul on Wed Mar 19, 2014 12:46 pm
    Hi ,
    Some ultimate arangements for the Push Rods and Propeller Shaft Sealing :
    LOS ANGELES build logs Push_r10
    LOS ANGELES build logs Push_r11
    LOS ANGELES build logs Final_10
    LOS ANGELES build logs Final_11
    LOS ANGELES build logs Final_12
    LOS ANGELES build logs Wite_g10
    Post  profesorul on Fri Mar 21, 2014 7:21 pm
    And some Little Work to Day . Doesn't Matter if after 4H of hard working I end up with 2 BROKEN pieces !!! .
    The Biggest one was the FIRST to see how is it going and what I have to do . It seems there is not always true what they say: NEXT TIME is Going to Make Better
    LOS ANGELES build logs Rodes_10
    How is it cold these SMALL Black piece?
    LOS ANGELES build logs Rodes_11
    How is it cold these BRONZE Piece I made ?
    LOS ANGELES build logs Rodes_12
    Where I can get those SMALL Black piece , 3mm ; 4mm ; 5mm inside Diameter ?.
    willte
    Post  willte on Fri Mar 21, 2014 7:55 pm
    little black things are E clips you can get them on e-bay the parts you made clevice links
    Post  profesorul on Fri Mar 21, 2014 8:03 pm
    THANKS @willte .
    Post  profesorul on Mon Mar 24, 2014 10:52 am
    HI there ,
    Some activity on the project.
    I did the rudders and dive planes bushings connectors for control rods ;
    Materials:
    - bronze bar 6mm diameter......I made the 2mm hole for rod and to hold them in place , was done with M3 threaded bolts ;
    - bushings for rods were made ​​of bronze 4mm bar with 2.1mm hole ;
    LOS ANGELES build logs Conect10
    LOS ANGELES build logs Conect11
    LOS ANGELES build logs Conect12
    LOS ANGELES build logs Sleeve10
    Post  tattooed on Mon Mar 24, 2014 6:46 pm
    nice work marius keep it going mate
      Current date/time is Sun Jan 26, 2020 5:58 am
