Let us know of your plans for 2019 and we will promote them on this Forum
.That's it for this year, folks! See you all in 2019.
»  Alexander Engel Russian typhoon Submarine
Yesterday at 10:33 pm by deepseadiver
Sun Dec 09, 2018 3:48 am by tsenecal
Tue Nov 27, 2018 6:20 pm by david f
» Newcomer to the forum?
Tue Nov 27, 2018 5:42 pm by david f
» 40Mhz Activity - waterfall display
Sun Nov 25, 2018 3:22 pm by timgarrod
» Tadcaster Pool Dive In, November 2018
Sun Nov 25, 2018 3:21 pm by timgarrod
» PIC and Arduino microprocessors
Fri Oct 26, 2018 10:49 am by david f
» Control yoke
Tue Oct 23, 2018 11:38 pm by merriman
» brushed motors
Mon Oct 22, 2018 11:47 am by merriman
Our users have posted a total of 10694 messages in 1756 subjects
We have 793 registered users
The newest registered user is Gazztank
    minne air pump
    Share
    willte
    minne air pump
    Post  willte on Fri Jan 10, 2014 1:56 pm
    seen this on ebay while getting a few things so bought one just over £8
    Re: minne air pump
    Post  merriman on Fri Jan 10, 2014 2:37 pm
    Careful with that one, willte: That unit does not have a dedicated nipple for the suction side of the pump -- OK for RCABS, but if you plan to draw a suction through an induction line, this little pump is useless.
    Re: minne air pump
    Post  Tom(ADMIN) on Fri Jan 10, 2014 2:42 pm
    They are good little pumps, Willie...they are made by a company called Koge, a German company, I think. I have one which will be going into the Type XX111, shame they only pump one way though, that's the only drawback. There is a matching solenoid valve which I have somewhere to release the air, or you can use a pinch valve, that works almost as well.
    Careful with the voltage though, they are only built for 4.8volts as an absolute maximum, I believe it says on the pump body the rating is 3.5 volts, but I have tested mine with 4.8v and it seemed ok at that.
    willte
    Re: minne air pump
    Post  willte on Fri Jan 10, 2014 3:00 pm
    it says 7.2 volts max on e bay just check and none left. got mine this morning the last time I saw some thing I fancy on ebay I took my time thinking about it and it had gone and that was a clear tube with end caps for £20 this time did not wait
      Current date/time is Wed Dec 12, 2018 9:46 pm
