In total there are 3 users online :: 0 Registered, 0 Hidden and 3 Guests :: 1 Bot
Our users have posted a total of 11066 messages in 1814 subjects
We have 837 registered users
The newest registered user is Stu g
    Floating Ball Cutt off for Ballast Tank
    timgarrod
    AMS Website Webmaster
    Floating Ball Cutt off for Ballast Tank Empty Floating Ball Cutt off for Ballast Tank
    Post  timgarrod on Sun Jul 21, 2013 6:28 pm
    Evening All,
    Sorry if this has already been cover but need some advise,
    I'm having to rebuild my Ballast system as the airbag is larger enough to lift and can't fit any more foam in side to lift the submarine to the correct height.
    My idea is to please two milk bottle ether side of the WTC, and pump the air into them to push the water out and and use the solenoid to release the air back into the WTC. the problem is I need a valve that has a ball inside the tube that then the bottle fill with water the ball will shut the tube to stop the water going into the WTC, do these exist or will I have to make them, also going to put on inside the tower so when the sub is surface any lost air is replaced in the WTC.
    Trying to make it like the one from SAS WTC from the revel Gato build
    Cheer
    Tm
    Floating Ball Cutt off for Ballast Tank Empty Re: Floating Ball Cutt off for Ballast Tank
    Post  nigele(ADMIN)2 on Mon Jul 22, 2013 8:52 am
    Morning,I have seen valves like this used but it was a long time ago it's like a mini systern valve,they where not very reliable and where a home brewed item,you might be better of using a water switch and electronic valve,I have seen some nice valves on ebay,under radio control submarines,and John Robinson can most likely help with a water switch.
    timgarrod
    Post  timgarrod on Sat Jul 27, 2013 10:52 am
    Thanks Nigele, I'll have a look into this, and research water switches
      Current date/time is Thu Feb 20, 2020 8:47 pm
